10 years agoHigh bandwidth data transfer between hps and fpga
Hi, I need to High bandwidth data transfer between hps and fpga. Which bridge should i use? I used light weight bridge but the speed of transfer data was up to 3MHz. Best Regards
10 years agoIf you are using Cyclone V SoC, there are FPGA-to-HPS and HPS-to-FPGA bridge that lets you select AXI width of 32, 64 or 128-bits. These bridges can accommodate larger bandwidth compared to light weight bridge.
