DValk1
6 years agoHi, The Quartus Prime programmer Pro doesn't find the device on board 1SM21BHU2F53E2VGS1 but lists devices 1SM21BHU2S... there is no F devices on the list. Using Quartus Prime Pro 19.1 or 18.1 How can I select the right device. Thanks, Des
DValk1
6 years agoHi Anand,
It is working now.
These are the steps:
- Autodetect the JTAG chain.
- Select one of the offered device numbers, really doesn't matter which and it is irrelevant that the target device is not on the list. Selecting one of them despite all that.
- Right-click on the FPGA device on the JTAG chain diagram and select "Edit>Change File"
- Select the .sof file and after it is read by the tool the device part number will change to the one encoded in the .sof file.
- Select program/Configure and select Start.
- Configuration ends successfully.
Point 2. was confusing, but once you mention that I can select any part and it should just work, made me experiment a bit.
Des
