EFroh's avatar
EFroh
7 years ago
Hi, I got the following Error when I tried to open my top level QSYS design: Error: An unexpected error occurred during Open System: java.lang.NullPointerException Debug: java.lang.NullPointerException
I have a top level QSYS with two QSYSes included. When I tried to rename some of the internal QSYS export ports, I got this error in the top-level QSYS.
I use 18.1.0.222 Quartus version.
How do I fix it?
  • EFroh's avatar
    EFroh
    Thanks! After I removed the disabled components it works!
  • KennyT_altera's avatar
    KennyT_altera
    Have you try the suggestion above? If yes, what is the result?
  • EFroh's avatar
    EFroh
    I work with CentoOS 6.7/6.9
    KennyT_altera
    What OS that you were using?
    check if you have any linked 'disabled' components in the system - if yes, try to delete rather than disable the components then system builder.
