17 years ago
Help:Cann't read or write EPCS in Nios II,why?
my system includes Flash,EPCS,etc,and has a EPCS controller.i want to read and write the EPCS in the nios.i tried to open the device using "alt_flash_open_dev()",but it's alway wrong--"can not open the device".so i used IORD()/IOWR(),and found Flash could be read/writen correctly,but EPCS couldn't be read/writen.Why?is anybody help me?
    mike21, i have set the nios boot from flash, in sopc builder, i set the reset address to flash. in nios ii ide setting, i also set the .text and .rodata flash to flash.
    hi everybody,
    iam using a nios II system generated from sopc builder.my system contains
    a CFI FLASH and SDRAM.Iam trying to simulate THE MEMTESTC.C exemple from the IDE.the sdram test is allright but the flash test is not.
    I have an error in Modelsim "
    -ERROR: Could not open flash
    i think that the problem is in the function
    alt_flash_open_dev witch don't recognize the flash
    i changed the code a little bit to be a ble to simulate
    static void TestFlash(int mode, int flash_type)
    alt_flash_fd* fd;
    int number_of_regions;
    int block;
    int y=0;
    flash_region* regions;
    int ret_code = 0x0;
    // alt_u8 entry[4];
    alt_u8 flashname[30];i replace this variable by CFI_FLASH_NAME
    printf("\n get flash name\n");
    ret_code = GetFlashName(CFI_FLASH_NAME,CFI);
    printf("\n openning the falsh\n");
    fd = alt_flash_open_dev(CFI_FLASH_NAME);
    if (fd)
    printf(" -Successfully opened %s\n", CFI_FLASH_NAME);
    /* Get some useful info about the flash */
    ret_code = alt_get_flash_info(fd, &regions, &number_of_regions);
    if (!ret_code)
    printf(" -Region 0 contains %d blocks.\n", regions->number_of_blocks);
    block = FlashFindErasedBlocks(fd, regions, number_of_regions, mode);
    /* If we're in TEST mode, ask if this block is okay to test. */
    if(( mode == TEST ) && ( block != QUIT_WITHOUT_TESTING ))
    printf(" -Block %d, at address 0x%X identified.\n", block, (regions->offset + (block * regions->block_size)));
    printf(" -Would you like to test this block? (y/n)");
    //GetInputString(entry, sizeof(entry), stdin);
    y=1;
    // if ( entry[0] == 'y' && entry[1] == '\n' )
    if(y==1)
    /* Test that Flash! */
    FlashRunTests(fd, block, regions);
    printf(" -Closing flash device \"%s\".\n",CFI_FLASH_NAME);
    alt_flash_close_dev(fd);
    else
    printf(" -ERROR: Could not open %s\n", CFI_FLASH_NAME);
    i tried a lot of things and i get the same result
    if somebody have an idea about how to solve this problem please HELP ME
