14 years agoHelp with metastability problem
Hi, I'm working on a vision processing based project at uni using a custom board built around a cyclone III and I am having to modify some vhdl code written by previous years students. A met...
14 years agoHi,
Thanks for the reply, I know there are possible many things wrong with my code, this is the first time I have ever used VHDL so it has been a bit of an experience to say the least. Quartus is spitting out warnings about inferred latches which I've read are a bad thing but i'm not sure how to design it any other way. Would you mind walking me through how you would go about designing this block (its a fairly simple block anyway) Basically what I am trying to make the block do is - Check if the frame data is valid by checking DVAL and FVAL (If the frame data is valid I am writing to the RAM block otherwise I am waiting while the data is uploaded) - Check if I am blocked (buffer_lock) and if so do nothing Writing state - if writing state just started (was previously uploading) reset the address and object count - Check if the obj data coming in is valid by checking VALID_IN - If data is valid write it to RAM and increment the address and object count - If RAM is full, the object count is equal to the RAM size do nothing Upload state - send out the object count and ready signal I'm also looking into timing analysis, as the output does seem like metastability but I do agree there are other problems with my code. Thanks, Mat.
