12 years ago
Help using transceivers in HDMI-port on Arria V GX starter board to send TMDS data
I am working on a project where I want to send TMDS data to a monitor using the HDMI-port on my Arria V GX starter board. I have only limited experience form VHDL design and have also only worked with Xilinx before, and never transceivers.
I am using a Arria V GX starter board with a 5AGXFB3H4F35C4N FPGA and Quartus II 13.0.
For a couple of days I been trying without success to send something using the 1.5-VPCML transceivers.
What I want to achieve is to send 3 x 10bit that comes in parallel at 148.5Mhz using 3 transceiver lanes sending at 1485 Mbps. I also want to send the 148.5Mhz clock over a transceiver output.
Whether I am trying with one or more lanes I am stuck with these errors and critical warnings respectively:
Error (175020): Illegal constraint of Transmitter channel to the region (169, 11) to (169, 11): no valid locations in region
    Info (175028): The Transmitter channel name: hdmi_tx_p
    Error (175005): Could not find a location with: PMA_DIRECT_CHANNEL (1 location affected)
        Info (175029): Transmitter channel containing PIN_AJ3
    Info (175015): The I/O pad is constrained to the location PIN_AJ3 due to: User Location Constraints (PIN_AJ3)
Critical Warning: HSSI PMA TX Serializer port 'CLKDIVTX' on node PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_pma:inst_av_pma|av_tx_pma:av_tx_pma|av_tx_pma_ch:tx_pma_insts.av_tx_pma_ch_inst|tx_pma_ch.tx_pma_ser should be connected
    Info: Must be connected
Critical Warning (11087): PMA direct channel(s) detected and needs to be constrained based on the guidelines in Arria V Device Handbook Volume 3: Transceiver chapter
Critical Warning (184043): Fitter was unable to find Transceiver Reconfiguration Controllers associated with the following 2 XCVR PHY IP component blocks
    Info (184044): Avalon Memory Map block PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_native:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_native.av_xcvr_native_inst|av_xcvr_avmm:inst_av_xcvr_avmm|avmm_interface_insts.av_hssi_avmm_interface_inst
    Info (184044): Avalon Memory Map block PHYnat_Tx:Trans|altera_xcvr_native_av:phynat_tx_inst|av_xcvr_plls:gen_native_inst.av_xcvr_native_insts.gen_bonded_group_plls.gen_tx_plls.tx_plls|pll.avmm.av_hssi_avmm_interface_inst
And some additional warnings which I think are irrelevant.
I am using a Native PHY IP core in direct PMA mode and have assigned the pins the I/O standard 1.5-VPCML. What might be the problem? Am I on the completely wrong track?
Your help will be highly appreciated!
Aron
    I am using native PHY in direct PMA mode, but do you mean that it could work better if I use PCS?
    I found this:
    http://www.altera.com/support/kdb/solutions/rd08272012_320.html
    Even though it is not the error codes I get it seems to indicate that my FPGA doesnt support PMA direct mode? That is strange though, because I am pretty sure that I have seen tables that show that it do support direct PMA.
    You may try to turn on PCS but bypass anything and see whether that works
    Hi Arion,
    Were you able to get your design working? I also have an Arria V GX Starter Kit that has an HDMI Rx HSMC daughtercard from Terasic connected to it. I want to do a simple pass-through design where the parallel video output from the daughtercard is sent to the HDMI Tx port on the board. Since there's no real HDMI transmitter chip on the board, I need to serialize the data myself.
    Lloyd
    If I am not mistaken, Arria V GX not support PMA direct, and it is only supported in Arria V GT device.
    You may quickly test out but create a simple PMA direct and compile in quartus to see whether it can pass fitter.
  • Timmio's avatar
    Timmio
    Does anyone solve this problem? I really want to send TMDS on Arria V GX Starter kit.
