Help required! Baremetal application with custom Preloader
See ug_soc_eds.pdf from Altera site all from top to bottom !
In "HPS Preloader User Guide" is described a process of generation. Binary file will be filled to QSPI to address 0 (4 times of 64K), your program -- to 6x64K), for make binary image use arm-altera-eabi-objdump.exe with address 02000000 that will be used in Preloader to load program to SDRAM.Hello,
I have a custom board with cyclone V SOC . I have a 1Gbit QSPI flash attached to the HPS portion of SOC. I want to boot the HPS with qspi flash. I able to do it debug mode. But not able to do it in program mode. what i mean is that i am able to load the rbf files into the qspi flash and read back this files and program the fpga successfully in debug mode. But when i try to do it program mode it is not working. I have generated preloader_-mkpimage.bin file with all the necesssary settings as mentioned in HPS qspi boot guide documentation. i load this preloader-mkpimage in 0x00000000 address of QSPI flash using the commands in SOC Command shell. then i load my application bin file generated after compilation of my design at 0x60000 address of flash by using commands in SOC EDS Command shell. Both this operation is successfull. MSEL pins are correctly selected for QSPI Boot. When i reboot the equipment the system is not booting. Am i missing certain settings at bsp generation or in make file or the linker file. Please specify.
Avi
