17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is
programming to FPGA directly. but FPGA has no reaction after programming,although the process is going on sucessfuly to 100%. this problem comes suddenly, as this FPGA work correctly before.any one who once met this problem ,give me help ,thanks!13 Replies
Thank you for your reply , I use an old one, the same one as I use before!
Have you tried measuring the clocks, pll lock signals and resets? Another thing can be to program something else into the fpga. Some simple design that toggles pins or something like that just to see if the FPGA or the design is the problem.
Best Regards, Ola Bångdahl (trying to avoid doing actual work...) - Altera_Forum
--- Quote Start --- The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no reaction after programming,although the process is going on sucessfuly to 100%. this problem comes suddenly, as this FPGA work correctly before.any one who once met this problem ,give me help ,thanks! --- Quote End --- Hi, are you using a new programming file or an old one which runs before ? Kind regards Gerd
