17 years agohelp ON EP2S60 FPGA
The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no rea...
17 years ago --- Quote Start --- The FPGA refuse to work after I program it! I use two way to program my design, one is programming to EPC16 which is connect to FPGA, another is programming to FPGA directly. but FPGA has no reaction after programming,although the process is going on sucessfuly to 100%. this problem comes suddenly, as this FPGA work correctly before.any one who once met this problem ,give me help ,thanks! --- Quote End --- Hi, are you using a new programming file or an old one which runs before ? Kind regards Gerd
