14 years agohelp on burst transfer with DMA
Hi guys, I am using a DMA core to manage burst transfer between a SDRAM and a SRAM on a DE2-115 board. For the DMA core, I set DMA length register width to be 10 bits, and max burst size ...
14 years ago --- Quote Start --- Hi leon...i am trying to use this dma for the same purpose...i tried to send an array which defined on the sdram to the sram throught the dma, but without any success...how can i define from which address on the sdram i start the data transfer and to what address i transfer them? Thank u very much --- Quote End --- Hard to say clearly... if you like, please send me your email and I will send you my code. It is around 27M after compression.
