16 years ago
help needed!!!
I am trying to do my assignment, I got this error in my port map
Error (10500): VHDL syntax error at FA.vhd(34) near text "port";  expecting "(", or "'", or "."
Error (10500): VHDL syntax error at babi3.vhd(38) near text ")";  expecting "<="
this my program...the error is in my port map???
I am newbie in Quartus...help me plz...:confused::confused::confused::confused:
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity DU is port(
        clk,rst                    :    in std_logic;
        dataA,dataB                :    in std_logic_vector(31 downto 0);
        Psel,Qsel,Rsel,Tsel        :     in std_logic_vector(1 downto 0);
        Use1,Wsel                :    in std_logic_vector(2 downto 0);
        ldA,ldB,ldE1,ldE2,ldM1,ldM2,ctrlM1,ctrlM2,ldP,ldQ: in std_logic;
        A_tp,B_tp                :    out std_logic_vector(31 downto 0);
        E1_tp,E2_tp,P,eq,lt     :    out std_logic_vector(7 downto 0);
        M1_tp,M2_tp,Q            :    out std_logic_vector(21 downto 0)
end DU;
architecture DU_arch of DU is
    signal Ain,Bin        :std_logic_vector(31 downto 0);
    signal E1in,E2in    :std_logic_vector(7 downto 0);
    signal M1in,M2in    :std_logic_vector(21 downto 0);
    signal zero1        :std_logic;
    signal Pin            :std_logic_vector(7 downto 0);
    signal Qin            :std_logic_vector(21 downto 0);
component RegE1 port(
    d            :    in std_logic_vector(7 downto 0);
    en,clk,rst    :    in std_logic;
    q            :    buffer std_logic_vector(7 downto 0));
end component;
component RegE2 port(
end component;
component RegA port(
    d            :    in std_logic_vector(31 downto 0);
    q            :    buffer std_logic_vector(31 downto 0));
end component;
component RegB port(
end component;
component RegM1 port(
    d                    :    in std_logic_vector(21 downto 0);
    ldsh,en,w,clk,rst    :    in std_logic;
    q                    :    buffer std_logic_vector(21 downto 0));
end component;
component RegM2 port(
end component;
begin
zero1 <= '0';
RegA port map( dataA,ldA,clk,rst,Ain);
RegB port map( dataB,ldB,clk,rst,Bin);
RegE1 port map( E1in,ldE1,clk,rst,E1_out);
RegE2 port map( E2in,ldE1,clk,rst,E2_out);
RegM1 port map( M1in,ctrlM1,ldM1,zero1,clk,rst,M1_out);
RegM2 port map( M2in,ctrlM1,ldM1,zero1,clk,rst,M2_out);
RegP port map( Pin,ldP,clk,rst,P);
RegQ port map( Qin,ldQ,zclk,rst,Q);
    --- Quote Start ---
    The is keyword in component declaration is optional. As said, the error is in component instantiation. It simply misses instance names.
    regainst: RegA port map( dataA,ldA,clk,rst,Ain);
    --- Quote End ---
    Istance names missing is one of the errors. Ports declaration are also needed to be added. The fellowing information is I got after adding instance names. I think checking several times after constructing programme could greatly avoid those errors.
    ** Error: E:/modelsim_prog/du.vhd(69): (vcom-1136) Unknown identifier "e1_out".
    ** Error: E:/modelsim_prog/du.vhd(70): (vcom-1136) Unknown identifier "e2_out".
    ** Error: E:/modelsim_prog/du.vhd(71): (vcom-1136) Unknown identifier "m1_out".
    ** Error: E:/modelsim_prog/du.vhd(72): (vcom-1136) Unknown identifier "m2_out".
    Good Luck!
    Salming
    try
    component RegE1 is port(
    and do the same for all your component declarations.
