16 years agohelp needed!!!
I am trying to do my assignment, I got this error in my port map Error (10500): VHDL syntax error at FA.vhd(34) near text "port"; expecting "(", or "'", or "."
Error (10500): VHDL syntax error ...
16 years ago --- Quote Start --- The is keyword in component declaration is optional. As said, the error is in component instantiation. It simply misses instance names.
regainst: RegA port map( dataA,ldA,clk,rst,Ain); --- Quote End --- Istance names missing is one of the errors. Ports declaration are also needed to be added. The fellowing information is I got after adding instance names. I think checking several times after constructing programme could greatly avoid those errors. ** Error: E:/modelsim_prog/du.vhd(69): (vcom-1136) Unknown identifier "e1_out".
** Error: E:/modelsim_prog/du.vhd(70): (vcom-1136) Unknown identifier "e2_out".
** Error: E:/modelsim_prog/du.vhd(71): (vcom-1136) Unknown identifier "m1_out".
** Error: E:/modelsim_prog/du.vhd(72): (vcom-1136) Unknown identifier "m2_out".Good Luck! Salming
