12 years agoHelp my with my Graduate Project's Idea to make it real by using FPGA
Hi everyone Before i make this thread i search in internet about my idea if there is any one make it before but i didn't find anything I am Haider Ali from Iraq I have 22 years old n...
12 years ago --- Quote Start --- why there is no reply it's not important you know the solution for my problem or you can help me to replay just reply and give me any opinion you have may be you could help me and then i will be grateful to you I'm not asking for something hard or Unreal please i really need your help --- Quote End --- Hi Haider, I am no expert on fpga boards. But I will make this point. Why use PC or two fpga boards at all. Use one fpga board to send and receive data. I mean you can put data in fpga rom directly then send it through DAC (and for two level signal you may not need DAC but use the io directly). From FPGA it goes to fibre optic channel and received by same fpga (ADC or io) and check received data against the sent rom content. You will need therefore to look around for fpga boards that support fibre optic and if not you will need to add that support. In principle many modern fpga can manage speeds up to 300MHz or so. Wish you safe summer in Iraq.
