17 years agoHelp me to config ADV7181B with I2C core on DE2 kit
Hi all,
I try using SOPC with Nios II and Microtronix I2C core to configure ADV7181B (video convert IC on DE2 kit) , but it not work. Could anyone help me to fix this problem. Thanks for reading! This `s my C code: # define I2C_BASE 0x00000020# define OUT_LED (unsigned char *) 0x01003000 int i2c_write_adv(unsigned char slave_addr); void write_byte (unsigned char reg_addr, unsigned char data); int main() { i2c_write_adv(0x20); return 1; } int i2c_write_adv(unsigned char slave_addr) { int i; // ADV Address IOWR_MTX_AVALON_I2C_ADDR(I2C_BASE, slave_addr); // Start Condition IOWR_MTX_AVALON_I2C_CONTROL(I2C_BASE,MTX_AVALON_I2C_ENABLE | MTX_AVALON_I2C_MASTER_STANDARD | MTX_AVALON_I2C_START ); // Wait for event while( !(IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_IRQ) ); // Clear interrupt IOWR_MTX_AVALON_I2C_STATUS(I2C_BASE, 0); // Check if ADV responded if (IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_NACK) { printf("ADV not found.\n"); return 0; } write_byte (0x15,0x10); // Stop Condition IOWR_MTX_AVALON_I2C_CONTROL(I2C_BASE,IORD_MTX_AVALON_I2C_CONTROL(I2C_BASE) | MTX_AVALON_I2C_STOP); // Wait for event while( !(IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_IRQ) ); // Clear interrupt IOWR_MTX_AVALON_I2C_STATUS(I2C_BASE, 0); // Disable IOWR_MTX_AVALON_I2C_CONTROL(I2C_BASE, 0); return 1; } void write_byte (unsigned char reg_addr, unsigned char data) { // write address IOWR_MTX_AVALON_I2C_DATA(I2C_BASE, reg_addr); // Wait for event while( !(IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_IRQ) ) ; // write a byte(fill transmit buffer) IOWR_MTX_AVALON_I2C_DATA(I2C_BASE, data); // Wait for transmit buffer empty while( !(IORD_MTX_AVALON_I2C_STATUS(I2C_BASE) & MTX_AVALON_I2C_IRQ) ) ; } my project is attachNo RepliesBe the first to reply
