17 years ago
help me please -cyclone device
can you tell wath do an altera FPGA device need to be operable. if i buy an cyclone fpga what other thins i need to buy to design my hardware?
    hi guys, thanks for the help. This is my situation:
    my overall system is an
    ADC --> FIR filter --> upsampling(4) --> DAC.
    I've already implemented the above system using a stratix II DSP kit. Now i want to build my own hardware (prototype) using only the necessary elements with a cyclone fpga. can you list me what are the elements do i need to make this system?
    Starting with a Dev Kit is a good suggestion. On the other hand, you can start a hardware design from the scratch as you would do e.g. with a microprocessor. The device handbook contains all necessary information, but some design experience is required to understand it completely, I think.
    To answer the question strictly, you need at least a dual (VCCINT/VCCIO) power supply, a clock source, nonvolatile configuration memory (not absolutely necessary during test), a JTAG connector and the user IO to be interfaced with the FPGA.
    Also an Altera or compatible third party USB Blaster or Byte Blaster.
    You have not provided enough details for us to help you out.
    Just get a development board with the Cyclone from a vendor. It will have enough hardware on there to get to started.
