17 years ago
Help me in translation of VHDL to verilog
Hello!
How can i convert a two-dimentional output & input port of vhdl into a verilog.
vhdl:
type VARIABLEARRAY is array (1 to NBRVARIBLE_CT+10 ) of SLV32;
one input port varaarayin is declared as a type of VARIABLEARRAY.
& one output port vararrayout is also declared as a type of VARIABLEARRAY.
I need a equivalent code for this because verilog didnt support 2-D array as input or output port.am i correct?
    @GKP,
    I am explaining with the help of example.
    e.g.
    variablearray is array (1 to nbrvarible_ct+10 ) of slv32;
    the equivalent memory space occupy by this 2-D array in terms of 1-D array
    is...
    var1[(NBRVARIBLE_CT+10)*32:0] ;//here var1 is the array of (NBRVARIBLE_CT+10) locations & the each location of this array is of 32 bit wide..
    I hope this is the proper explaination for you.
    --- Quote Start ---
    Hello!
    vhdl:
    --- Quote End ---
    can you explain what you mean with a 2-D Array input/output ?
    GPK
