9 years agoHelp me!! How to Configure EP3C25E144A7 (Cyclone III) with Fast Active Serial ?
https://alteraforum.com/forum/attachment.php?attachmentid=13642&stc=1
I want to Configure for chip EP3C25E144A7 with Fast Active Serial Fast (AS Fast POR), Help me to setup MSEL pins ? Thank you very much!! quote: https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahukewj688dg7evtahxgzlwkhbuuciqqfggumae&url=https%3a%2f%2fwww.altera.com%2fliterature%2fhb%2farria-10%2fa10_config.pdf&usg=afqjcnfkvt6xstwoxe2mcnpx9lmjstiyyw&sig2=ukd7-oxb4xzumkni_17mtq "Smaller Cyclone III devices or package options (E144, M164, Q240, F256, and U256 packages) do not have the MSEL[3] pin. The AS Fast POR configuration scheme at 3.0- or 2.5-V configuration voltage standard and the AP configuration scheme are not supported in Cyclone III devices without the MSEL[3] pin. To configure these devices with other supported configuration schemes, select the MSEL[2..0] pins according to the MSEL settings in Table 9–7". "FPP configuration is not supported in the Cyclone III E144 device package of Cyclone III devices"2 Replies
The quoted statement is at least misleading. The packages without MSEL[3] are apparently bonding MSEL[3] to MSEL[2] pin, leaving only the below listed configuration options:
https://www.alteraforum.com/forum/attachment.php?attachmentid=13643 - Altera_Forum
you can't:
--- Quote Start --- The AS Fast POR configuration scheme at 3.0- or 2.5-V configuration voltage standard and the AP configuration scheme are not supported in Cyclone III devices without the MSEL[3] pin. --- Quote End ---
