16 years agoHELP ME about EP2C20Q240C8,PLEASE!
HI ALL I'm using the cycloneII(EP2C20Q240C8).I want to know what the difference the pin 178 and the others.when i use the pin 178 as LVTTL output,it cannot output a wave (frequency about 25MHz whe...
16 years ago --- Quote Start --- i also found the chip become very hot --- Quote End --- That's actually alarming. I don't think, that it happens because you're using a particular pin as output. As a more likely reason, you may have shorted a pin that is driven as output (e.g. an unused pin) or the device is simply damaged. --- Quote Start --- you mean the signal tap is unbelieveable --- Quote End --- I mean, that some pins may be unaccesible for SignalTap by it's nature. SignalTap uses existing IO buffers and registers. If these resources don't exist for a particular pin, SignalTap can't work. There are some cases, where SignalTap can't access a pin (e.g. withh DDIO function) or doesn't necessarily reflect the pin state correctly (e.g. input function of bidirectional pins, but only in some cases, depending on other design parameters). I would expect problems also with dedicated clock outputs, but I'm not sure about.
