9 years ago
Help how to Mapping HPS IP Peripheral Signals to the FPGA Interface
Hi all,
I'm reading the application note found at : https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/an/an706.pdf
I have a DE1-SoC board. I want to send the data to the PC trought the ethernet interface, on the DE1-SoC board the ethernet interface is from the HPS. I'm tried to read this document but I'm lost in that pdf and I didn't found any example.
I think that I have to use the TSE IP but I don't know how can I do.
Anyone can help me?
Best regards
Gianluca
    --- Quote Start ---
    Hi Gianluca,
    i don't exactly understand what's your problem, but when you want to map the pins from the emac0/1 periphals from the hps to the FPGA you have to do the following:
    1.) In Qsys you have to edit the hps component. In the periphial pins tab -> EMAC0/1 pin you have to select FPGA. Then generate the HDL Files.
    2.) Assign the pins like it is described in AN706.
    3.) Run a full compilation
    4.) Update the prelaoder section, how do you do this is described at rocketboards
    5.) Run the board with the new fpga image
    Best regards
    --- Quote End ---
    Thank you for your reply.
    Yes this is exactly what I have to do. Before start to route the EMAC1 I try with a simple example that consist in drive a HPS_LED from the fpga and this example work properly.
    I'm trying to follow the AN706 but I don't understand how I can connect the data from the Triple speed ethernet IP to the emac signal.
    In the page 10 of the AN706 on the datasheet it says that these pins pht_txd_o [3: 0] must be connected to PO_TX port [3: 0] but the PO_TX of the TSE IP is also an input. I'm doing something wrong?
    Have I to use the triple speed ethernet IP in order to send data on the ethernet?
    If you do not pick and use the FPGA from EMAC1 LOANIO function when I perform the synthesis I get an error because some pins, such as the TX or RX are unidirectional, but when I use the LOANIO are inout.
    I'm trying different ways, can anyone help?
    Best Regards
    Gianluca
    Hi Gianluca,
    Best regards
