15 years agoHelp: How can I implement e(t^2/l^2) in VHDL
Hi! Experts, Could anyone please help me to implement e(t^2/l^2) in VHDL? where t is continuous time and l is a constant. Thank you very much in advance. Regards, Akilan.T
15 years ago --- Quote Start --- Could anyone please help me to implement e(t^2/l^2) in VHDL? where t is continuous time and l is a constant. --- Quote End --- What is the maximum value for 't' and what is the resolution of 't' , and the range for 'i'? What precision do you need for the result? If you want to use a Look-Up Table you will need ((tmax / resolution(t)) * precision) memory bits. If that exceeds the number of available you will have to find a (mathematical) solution to compute the result.
