15 years agoHelp: How can I implement e(t^2/l^2) in VHDL
Hi! Experts, Could anyone please help me to implement e(t^2/l^2) in VHDL? where t is continuous time and l is a constant. Thank you very much in advance. Regards, Akilan.T
15 years agoIf your application is not critical you can use a small LUT e.g. 256 points then interpolate (linearly) between two values as they occur by finding the difference between input (t) value and nearst LUT values. i.e. some t values will point directly, most others will point in between LUT points so a basic calculation is needed to adjust the result.
