15 years agohelp for audio codec using VHDL
i am a begineer at using altera DE2 board and VHDL. i have to complete my project with in 10 days time but dont have any idea of where to start and how.. help ......... i need to build a duplex au...
15 years ago --- Quote Start --- hi mbharat........ the DE1 use cyclone 2 FPGA?????? i had two board .... DE2 and cyclone 3 dev board and i wanna port your code to my boars........ the DE2 is better to do it i guess....... --- Quote End --- You can port the hardware to an FPGA board that contains the Wolfson WM8731 audio codec. --- Quote Start --- another question..... about the pin clock_27[1..0] .... you conect this pin to a external clock??? and gpio_0[35..0] where i need conect this????? i2c pins are used for what???? to configure ????? --- Quote End --- If you download DE1AudioAdcDac.zip from the link in this thread and unzip it, you should find a project report under the Report folder. Read and understand that report, it answers all your questions. Bart
