15 years agohelp for audio codec using VHDL
i am a begineer at using altera DE2 board and VHDL. i have to complete my project with in 10 days time but dont have any idea of where to start and how.. help ......... i need to build a duplex au...
15 years ago --- Quote Start --- i am a begineer at using altera DE2 board and VHDL. i have to complete my project with in 10 days time but dont have any idea of where to start and how.. help ......... i need to build a duplex audio system that works similar to a phone but here CDMA must be considered. first i would like to have some good advice on where to start and how .... on audio CODEC any help would be more than appreciated --- Quote End --- I have attached a few pieces of my hardware description in VHDL. Note that is for the Wolfson WM8731 on the DE1 board. But the DE2 has the same chip so the attached hardware description should work with the appropriate pin assignment modifications. Note that I could not upload clockBuffer.vhd because of the 5 file limit. BUT you should be able to easily create the clockBuffer using the MegaIP wizard. Also I do not claim my code is the best (especially the i2c part) but it does the job. You should go through the code and understand how it works. Honestly, if you are a beginner with VHDL and DE2, it may be very difficult to finish this project in 10 days (unless you have previous hardware design experience). Good luck. Bart
