16 years agohelp beginner "report not available"
Can somebody answer what is probably a simple question: How do I get to see reports after compilation? All I get is "reports not available" Note. I am a real beginner, so I setup ver 10.0s...
16 years agoHi
Thanks for your interest. I used the exact device specified in the tutorial, a EP3SE50F484C2 from Stratix 3. There were a few errors listed. (See below) After reading you reply I tried a few other devices from different families and got and got similar results from cyclone. However, using a MAX device produced no errors, full compilation, but STILL NO REPORTS. This is the sort of thing I get at the message window with stratix, cyclone: Info: You have a valid up-to-date license Info: You have a valid up-to-date license Error: Selected feature of TimeQuest Timing Analyzer is not available with your current license, or license does not exist Info: You have a valid up-to-date license Error: Current module quartus_asm ended unexpectedly Error: Quartus II Full Compilation was unsuccessful. 2 errors, 0 warnings And with MAX II: Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: You have a valid up-to-date license Info: Quartus II Full Compilation was successful. 0 errors, 0 warnings Are there limitations with the web edition and licensing that cause this problem? Hope this information is useful, and thanks again
