Hello, is there a known problem with the ethernet MACs DMA controller in the CYCLONE V SOC devices ?
- 8 years ago
Dear Anand,
Dear Nooraini,
thank you for getting back to me and sorry for my late reply.
Meanwhile it seems that we have found the reason for the failing
DMA transfers from GMAC. The 'shared attributes override' Bit in
the L2C Cache controllers AUX_CONTROL Register must be set to
one. This can be done either via bootloader patch or by adding the
"arm,shared-override" parameter to the L2C node in the devicetree.
Otherwise the Rx Path fails after some minutes when theres high
network traffic.
@ Anand : Yes I was able to ping the description. I have added some debug
code to the driver to output the descriptor ring immediately when the DMA#
fails.
Please close this request.
All the best,
Andre
Currently I am reviewing the forum for any open questions and found this thread. I apologize that no one seems to answer this question that you posted. Since it has been a while you posted this question, I'm wondering if you have found the answer? If not, please let me know, I will try to assign someone to assist you. Thank you.
Nooraini
