18 years agohardware architecture of af altera cyclone
hello, i have a live design evaluation board which altera cyclone on it.i have programmed a soft-core processor on that fpga.all i need to do is, write a simple programm to the processor in ord...
18 years ago --- Quote Start --- hello, now i don't know how to connect the eclipse cdt with my processor using architecture of altera.. --- Quote End --- Eclipse is an environment for coding, compiling and downloading. It is a generic environment and can be used for any processor. So, if you want to use it for your zpu processor, then you should prepare a library of drivers (= software programs that zpu will use to communicate with the peripherals in your specific project). I am sure they may already be available on zpu source sites. Else, you need to code drivers. Please also go through Eclipse documentation in this regard. --- Quote Start --- and the connection between the processor and led.. --- Quote End --- Once you are done with a software library of drivers, this is pretty simple. Your software library will also contain zpu drivers to communicate with led ports (actually LED is just one device from a family of devices which are driven by single ttl/otherwise lines). You will have several functions in your library (which you will have coded yourself) to control and monitor status of LEDs like LED_Read, LED_Write etc. --- Quote Start --- simply i dont know how the whole system works..can someone guide me step by step?? --- Quote End --- Though this is not very tough, it is important that you spend some time coding drivers. A deep perusal of NIOS drivers will be a good start as also the way libraries should be coded in Eclipse.
