abeli1
7 years agoHang system when access to BAR0, SV HARD IP CORE AVMM DMA
Good afternoon colleagues
Help me to understand
1) Launched PCIE HARD IP 256-bit AVMM DMA
2) Trying to run the dma controller
3) I am writing data in a bar0 from Linux
4) As soon as I call the iowrite32 35 times, the system freezes. At the same time, after each entry, I try to read the data and get 0xFFFFFF
Please tell me what could be the problem?
c++ driver code
init_chrdev(..)
pci_enable_device(..)
request_mem_region(
pci_resource_start(_device, 0),
pci_resource_len(_device, 0),
ALTERA_DMA_DRIVER_NAME
pci_iomap (...)
pci_enable_msi(...)
iowrite32 (
cpu_to_le32(tmp_rand),
(u32 *)(_dev_data_ptr->bar[0]) + i
);Also, if my driver is loaded, I need to contact any utility to pci (lspci for example), the system immediately hangs
Under windows the same
Thank you in advance
1 Reply
- SengKok_L_Intel
Are you referring to any example design from Intel PSG? Or the driver and PCIe design is created by yourself?
Regards -SK
