H-tile Hard IP Fitter Failed in Stratix10mx
I just set the pin placement as the schematic said. Now I suspect the sdc file about the native phy clk has problems. Which files should I refer to to place the RX_CLK* and TX_CLK* in the right channel?
The sdc in the project is auto generated by the htile IP.
set RX_CLK0 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[0].s10_xcvr_native_inst|*rx_pcs_x2_clk|ch0]
set RX_CLK1 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[1].s10_xcvr_native_inst|*rx_pcs_x2_clk|ch0]
set TX_CLK0 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[0].s10_xcvr_native_inst|*tx_pcs_x2_clk|ch0]
set TX_CLK1 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[1].s10_xcvr_native_inst|*tx_pcs_x2_clk|ch0]
set RX_CLK2 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[2].s10_xcvr_native_inst|*rx_pcs_x2_clk|ch0]
set RX_CLK3 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[3].s10_xcvr_native_inst|*rx_pcs_x2_clk|ch0]
set TX_CLK2 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[2].s10_xcvr_native_inst|*tx_pcs_x2_clk|ch0]
set TX_CLK3 [get_clocks u_0|av_top|alt_ehipc2_0|alt_ehipc2_hard_inst|altera_xcvr_native_inst|g_native_phy_inst[3].s10_xcvr_native_inst|*tx_pcs_x2_clk|ch0]
Fitter passed design QAR file
- Deshi_Intel5 years ago
Fitter error explanation analysis
