12 years agoGXB:tranceiver transmission time issue
Hi dears:
I have a board which has two same FPGA. Each FPGA has one transmitter. These two FPGA are configured with same configuration file. I use aonther board which has only one FPGA to receive these two transmitter channels. I did a test, transmited data in turn. I used signaltap to check these two different GXB channel and found that they arrive at different time. Every cycle may be different, sometimes may be aligned. sometimes, may several clock cycles ahead or later. Is it possible that the data propagation times inside different GXB links are different? I attached two jpg files, the first shows these two receivers have 6 clock cycles differ each other, it's strange that why are there anoter more 4 clock cycles time added? The socond shows these two receivers have 2 clock cycles differ each other (It's ok, for I make this two clock cycles difference in transmitter side). Also, I found the delayed channel sometimes could arrive early than the aonther channel! Very strange.
