13 years agoGXB:tranceiver transmission time issue
Hi dears: I have a board which has two same FPGA. Each FPGA has one transmitter. These two FPGA are configured with same configuration file. I use aonther board which has only one FPGA to recei...
13 years ago --- Quote Start --- Can guide me how to simulate two FPGA? According my understant, one testbench should run inside single chip! --- Quote End --- The simulator does not know about chips, it just knows about HDL code, so your simulation of two FPGAs is a top-level design containing two instances of a transceiver block with TX1->RX2 and RX1->TX2. You could also think of this as one chip with two transceiver blocks connected. Cheers, Dave
