Guidance for using UART IP if Quartus
- 1 year ago
All is documented here: https://www.intel.com/content/www/us/en/docs/programmable/683130/24-3/uart-core.html
The memory map is here: https://www.intel.com/content/www/us/en/docs/programmable/683130/24-3/register-map-38176.html
The _inst.v is an instantiation template, not the actual instantiation. You copy the template into your code and edit it to connect to the rest of your project.
As for your usage, that's up to you. You can use the JTAG UART IP with Nios to send and receive characters while the design is running in hardware for debug.
Hi
I’m glad that your question has been addressed, I will now transition this thread to community support. If you have a new question, Please login to ‘https://supporttickets.intel.com/s/?language=en_US’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
Jingyang, Teh
