james57's avatar
james57
3 years ago
GSRD - Build Yocto Fails
After following the GSRD SD Card Version for H-tile S10
Stratix 10 SoC H-Tile GSRD | Documentation | RocketBoards.org
I have gotten to the step to -
"bitbake image"
The build gets to 97% when it fails saying
"gsrf_soc_fpga/stratix10_gsrd_rootfs/tmp/deploy/images/startix10/devicetree/socfpga_startix10_socdk.dtb No such file or directory"
I was wondering if I have missed a step in the GSRD and need to go back to generate this device tree blob, or if I generate it elsewhere, and place it into the directory.
If I need to externally create it, steps to follow would be amazing.
  • Hi,
    Can you please try first clean the build project and copy again the linux-socfpga .dtsi file to your yocto project after converting to .dtb.
    Tiwari
  • Jeet14's avatar
    Jeet14
    Thanks for marking that problem got resolved now.
    With that, I now transition this thread to community support.
    Thank you.
    Tiwari
  • Jeet14's avatar
    Jeet14
    Tiwari
  • james57's avatar
    james57
    Here is a what my terminal says after bitbake image fails
  • Jeet14's avatar
    Jeet14
    Let me know if you have any other query on this matter.
    Jeetesh
    • james57's avatar
      james57
      Hi @Jeet14 ,
      Thanks for getting back to me.
      I followed the link that you suggested. I cloned the "linux-socfpga" github and was able to see the proper files in the specified directories
      ./arch/arm64/boot/dts/altera/socfpga_stratix10_socdk.dts
      and
      ./arch/arm64/boot/dts/altera/socfpga_stratix10.dtsi
      although now I am a little confused how to structure my files such that "bitbake_image" command is able to see these files so the build can finish.
      Does this "linux-socfpga" files that was cloned go "TOP_FOLDER" directory from the GSRD, or does it go in the "gsrd-socfpga" folder cloned from -
      langdale https://github.com/altera-opensource/gsrd_socfpga
      Please let me know if you understand my question or if I am missing something.
      James
