12 years agoGSM and GPS module for altera fpga
I wanna know,what the specification of gsm and gps module that can connected with altera fpga board.My projects related with communicate system which i must use gsm and gps module.Hopefully you can prefer me what kind module that i must used.Thank you.-alif-
1 Reply
Most of the gsm and gps modules can communicate with a host through a serial interface, using either TTL/CMOS levels or RS232/RS422. You can use all those with an FPGA, you'll just need a UART IP inside. If the interface uses RS levels, you will also need a transceiver chip between the FPGA and the module.
