8 years agoGPIO vs HSMC pinout
Hi all, I am going to design high speed application. Because my cyclone V development kit (DE10- Standard) have two output options is GPIO and HSMC. I would like to know what the different betwe...
8 years agoHi,
1. HSMC:- It is a high speed connector, which supports 9.5GHz single ended signal and 10.5GHz for differential signal.Per pin current is around 2 A and good voltage rating. reliable in terms of the mating.
- Based on the frequency of fpga for high speed IO is around 500~600MHz only so we can use with in this frequency.
