10 years agoGlobal, Local, Regional, and Peripheral clocks
Hi All, How can I know what pins could be used as the Global, Local, Regional, and Peripheral clocks in the ArriaV device (as an example)? What difference between these clocks? Where to read ab...
10 years agoLook at the appropriate Pin-out file for your device. See pin-out files for altera devices (https://www.altera.com/support/literature/lit-dp.html#arria-v).
Under the Optional Function(s) column, you're looking for the CLK[0..11] pins. Cheers, Alex
