10 years agoGlobal, Local, Regional, and Peripheral clocks
Hi All, How can I know what pins could be used as the Global, Local, Regional, and Peripheral clocks in the ArriaV device (as an example)? What difference between these clocks? Where to read ab...
10 years agoThanks to all! It was a mistake of a board designer so he connected a clock source to a pin, which was not a dedicated clock pin. As the result, the fitter traveled to far for just picking up a global clock buffer. This travelling was resulted in the setup violations of about 3(!) clock cycles!
It seems I resolved the issue by switching the "Global Signal" pin attribute to OFF. https://www.alteraforum.com/forum/attachment.php?attachmentid=11546
