15 years agoglitich in the outputs
i am getting some glitiched in the outputs, i am not sure what is the reason of then glitich and how to get rid of them, the glitichs happen in the output that are not changing
15 years agothere is nothing wrong with 1 process style - it can actually help prevent errors. Plus it would register all your outputs for you. I think older books only recommend the 2 process style because at the time compilers were pretty crap at doing anything with source code outside a few templates. Now they are much much better.
You can basically do small mods to your 2nd process to make the whole thing work, plus you dont need a next_state signal:
Library ieee;
use ieee.std_logic_1164.all;
PORT (Right,Left,Hazard : IN STD_LOGIC;
Clk, Reset : IN STD_LOGIC;
LA,LB,LC : OUT STD_LOGIC;
RA,RB,RC : OUT STD_LOGIC);
END Vehicle_Tail_Lights_control;
ARCHITECTURE state_machine OF Vehicle_Tail_Lights_control IS
TYPE state_type IS (Idle,L1,L2,L3,R1,R2,R3,LR3);
attribute ENUM_ENCODING: STRING;
attribute ENUM_ENCODING of state_type: type is
"000 001 011 010 101 111 110 100";
SIGNAL current_state : state_type;
BEGIN
PROCESS(clk, reset)
BEGIN
if reset = '1' then
current_state <= idle;
elsif rising_edge(clk) then
CASE current_state IS
WHEN idle =>
Lc<='0';Lb<='0';La<='0';Ra<='0';Rb<='0';Rc<='0';
IF ( (Hazard='1') OR ((Left='1') AND (Right='1')))
THEN current_state <= LR3;
ELSIF ( (Hazard='0') AND (Left='0') AND (Right='1'))
THEN current_state <= R1;
ELSIF ((Hazard='0') AND (Left='1') AND (Right='0'))
THEN current_state <= L1;
ELSE
current_state <= Idle;
END IF;
WHEN L1 =>
Lc<='0';Lb<='0';La<='1';Ra<='0';Rb<='0';Rc<='0';
IF (Hazard = '1') THEN current_state <= LR3;
ELSE current_state <= L2;
END IF;
WHEN L2 =>
Lc<='0';Lb<='1';La<='1';Ra<='0';Rb<='0';Rc<='0';
ELSE current_state <= L3;
END IF;
WHEN L3 =>
Lc<='1';Lb<='1';La<='1';Ra<='0';Rb<='0';Rc<='0';
WHEN R1 =>
Lc<='0';Lb<='0';La<='0';Ra<='1';Rb<='0';Rc<='0';
ELSE current_state <= R2;
END IF;
WHEN R2 =>
Lc<='0';Lb<='0';La<='0';Ra<='1';Rb<='1';Rc<='0';
ELSE current_state <= R3;
END IF;
WHEN R3 =>
Lc<='0';Lb<='0';La<='0';Ra<='1';Rb<='1';Rc<='1';
WHEN LR3 =>
Lc<='1';Lb<='1';La<='1';Ra<='1';Rb<='1';Rc<='1';
END CASE;
end if; --clk
END PROCESS;
END state_machine;
