Glitch on DCLK during Active Serial Arria 10
Not sure if this is due to your board trace? Have you check if there is any distortion that cause the issue?
John,
It might be, but I have tried to eliminate the possibility. I have attached a screen grab of the layout. The purple vias are at the back of the Arria 10. R638 is the 22 ohm series termination resistor. I have tried removing R638 and installing a 1k ohm resistor from DCLK at the right pad of R638 to ground. I can still see the glitch with just 330 mils of trace.
What is the source of the output clock on DCLK when programming a flash and trying to boot from one using Active serial? Is it the internal oscillator or is it dependent on CLK_USER? I also have other differential clocks input to IOs, but I don't think the flash loader design has any way of knowing they're clocks before configuration.
If it matters, we're using the 10AX090N2F40E2SGJZ.
