Glitch on DCLK during Active Serial Arria 10
Not sure if this is due to your board trace? Have you check if there is any distortion that cause the issue?
- BenUhing5 years ago
John,
It might be, but I have tried to eliminate the possibility. I have attached a screen grab of the layout. The purple vias are at the back of the Arria 10. R638 is the 22 ohm series termination resistor. I have tried removing R638 and installing a 1k ohm resistor from DCLK at the right pad of R638 to ground. I can still see the glitch with just 330 mils of trace.
What is the source of the output clock on DCLK when programming a flash and trying to boot from one using Active serial? Is it the internal oscillator or is it dependent on CLK_USER? I also have other differential clocks input to IOs, but I don't think the flash loader design has any way of knowing they're clocks before configuration.
If it matters, we're using the 10AX090N2F40E2SGJZ.
