BenUhing
5 years agoGlitch on DCLK during Active Serial Arria 10
I have a PCB with an Arria 10 that I'd like to support both passive serial and active serial config. I can successfully configure the Arria 10 via JTAG and passive serial, but I cannot successfully p...
JohnT_Altera
5 years agoHi,
May I know if you change the MSEL after the FPGA is power up or before it is power up? If you change the MSEL after the FPGA is power up then I do not think you will be able to use Active Serial as the MSEL setting is only read during power up.
BenUhing
5 years agoJohn,
Thanks for responding. We won’t need to hot switch MSEL after power up. I’m only changing the position of the switch before power up.
