12 years agoGHRD interrupts
I would like to use the standard GHRD design to handle interrupt. It looks like the pushbutton interrupts are enabled in the Qsys design. I have no idea how to register a callback in Linux cod...
12 years agoAs far as I can tell, the altera yocto source package is still on 3.7. You could build the 3.7 Linux and do your testing unless there is a reason you need 3.8.
The following webpages should get you through the entire process. http://www.rocketboards.org/foswiki/documentation/gsrdgettingstartedyocto http://www.rocketboards.org/foswiki/documentation/gsrdsdcard
