12 years agoGHRD interrupts
I would like to use the standard GHRD design to handle interrupt. It looks like the pushbutton interrupts are enabled in the Qsys design.
I have no idea how to register a callback in Linux code on one of these interrupt lines. Can anyone help with some example Linux code that works with the GHRD? Thanks.8 Replies
I think you'd better write a linux driver for the button!
I have the Arrow SoCkit, and I have been struggling with this for a while. I'm digging into the device tree for the arrow board posted on rocketboards, and I found an entry for the gpio's.
agpio0: gpio@0xc0000000 { compatible = "altr,pio-1.0"; /* Register base 0xff200000 is for a light-weight bridge */ reg = <0xff200000 0x10>; width = <32>; /* There are 64 interrupts from the FPGA start at 72, so 45 has to be wrong */ interrupts = <0 45 4>; interrupt-controller; # interrupt-cells = <1>; gpio-controller; # gpio-cells = <2>; level_trigger = <0>; I verified this is what the Linux kernel sees by looking in the folder at /proc/device-tree/soc/gpio@0xc0000000 I'm worried about the comment : /* There are 64 interrupts from the FPGA start at 72, so 45 has to be wrong */ I wonder why that has to be wrong? This looks different from the Altera boards device tree entry, which is: button_pio: gpio@0x100c0 { compatible = "ALTR,pio-13.0.1", "ALTR,pio-1.0", "altr,pio-1.0"; reg = < 0x000100C0 0x00000010 >; interrupt-parent = < &hps_0_arm_gic_0 >; interrupts = < 0 41 1 >; width = < 2 >; /* width type NUMBER */ resetvalue = < 0 >; /* resetValue type NUMBER */ level_trigger = < 0 >; /* embeddedsw.dts.params.level_trigger type NUMBER */ # gpio-cells = < 2 >; gpio-controller; }; //end gpio@0x100c0 (button_pio) This entry has quite few differences from the arrow version. I have tried following the example here: C:\altera\13.0sp1\embedded\examples\software\Altera-SoCFPGA-Push-Button-Linux-GNU.tar.gz I was able to build the gpio-interrupt driver in the example. I used the yocto project kernel headers for the altera board to build against. (Not sure if this was the right way to do this.) For the arrow board, when I insert the altera-gpio.ko kernel module, ( with 'modprobe gpio_altera'), I find gpiochip224 in /sys/class/gpio. The next step I did was insert the gpio-interrupt kernel module I built from the example with the command 'modprobe gpio_interrupt gpio_number=224' So I look at /proc/interrupts and I see this: CPU0 CPU1 525: 123056 121886 GIC twd 648: 1 0 GIC eth0 656: 1 0 GIC dwc_otg, dwc_otg_pcd, d 667: 2280 0 GIC dw-mci 679: 0 0 GIC ff705000.spi 682: 0 0 GIC dw_spi0 684: 0 0 GIC dw_spi1 686: 0 0 GIC ffc04000.i2c 687: 0 0 GIC ffc05000.i2c 690: 6879 0 GIC serial 697: 9 0 GIC timer2 752: 0 0 altera-gpio (null) IPI0: 0 0 CPU wakeup interrupts IPI1: 0 0 Timer broadcast interrupts IPI2: 1127 1196 Rescheduling interrupts IPI3: 0 0 Function call interrupts IPI4: 1 2 Single function call interrupts IPI5: 0 0 CPU stop interrupts Err: 0 There is an entry for the altera-gpio interrupt, but it does respond when I push the button (No updating /proc/interrupts, and no message in 'dmesg') The '(null)' after the interrupt is concerning. Any help is appreciated. Thanks. - Altera_Forum
Hi ecullert
I have writen a hps gpio interrupt driver with kernel-3.8. I build the driver within the kernel and it works. I get the kernel source from http://www.rocketboards.org/foswiki/view/projects/sockitlinarolinuxdesktop In the dts I just add myself code gpio1: gpio@0xff709000 { compatible = "key"; reg = < 0xff709000 0x00001000 >; interrupts = <0 165 4>; }; The interrupt number in dts is 32 less than the number in GIC The I write my own driver (initial the driver and register the interrupt in kernel) This driver just uste the gpio interrupt but not fpga interrupt I hope the information be helpful for you! - Altera_Forum
TO_BE_DONE
Can someone please give some help on how to actually use the interrupt. I have a FIFO setup connected the light weight avalon master. The interrupt from the FIFO is connected to the HPS. But how do I set up the device tree. I read up somewhere to generate the device tree file from the sopcinfo file. I tried doing this but I got the following response. "Master and slave interfaces for the Transparent bridge in fifo_0 of type altera_avalon_fifo have different types." Any thoughts? Jack - Altera_Forum
@ecullert
Thank you for your very detailled help. I have done a "make" with linux-altera-3.7. Everything works fine in my virtual machine but not on my Evaluation Board. The Problem: I get an error for "insmod gpio_interruot.ko" because I should use kernel version 3.8.0. Is there an altera-linux-3.8? I have not found anything on Google. Best regards, Michael - Altera_Forum
As far as I can tell, the altera yocto source package is still on 3.7. You could build the 3.7 Linux and do your testing unless there is a reason you need 3.8.
The following webpages should get you through the entire process. http://www.rocketboards.org/foswiki/documentation/gsrdgettingstartedyocto http://www.rocketboards.org/foswiki/documentation/gsrdsdcard - Altera_Forum
Thanks a lot! :-)
