bt5
4 years agoGHRD for S10 SoC fails
Hi All, I've facing an issue for quite a while now running the GHRD for the stratix 10 SoC. Here's a screenshot of the problem space:
A quick recap: I downloaded Quartus Prime Pro 22.1,...
- 4 years ago
Hi JingyangTeh,
I managed to figure it out. My Ubuntu VM has 4 GB of RAM and the process that was constructing the HPS ip was consuming 8GB of RAM thus the process was being killed. I increased my RAM to 16 GB and the issue was solved.
Thanks for your suggestions.
Birane
bt5
4 years agoHi Jingyang,
I recommend making the minimum 32 GB, the problem i posted was fixed but further down in the makefile, at the fitter step, the process was again killed due to lack of memory. The most most memory intensive step seemed to go up in 20s of GB.
Birane
