GHRD for S10 SoC fails
- 4 years ago
Hi JingyangTeh,
I managed to figure it out. My Ubuntu VM has 4 GB of RAM and the process that was constructing the HPS ip was consuming 8GB of RAM thus the process was being killed. I increased my RAM to 16 GB and the issue was solved.
Thanks for your suggestions.
Birane
Hi bt5
Sorry for the late reply as there is a public holiday.
I just tried running the steps and it is working.
Did you run the nios2_command_shell.sh first before running the command of the make?
After you run the nios2_command_shell.sh you will see messages below:
Altera Nios2 Command Shell
Version 22.1, Build 174
Try running the nios2_command_shell.sh first before running the rest of the commands:
./nios2_command_shell.sh
make scrub_clean_all
make generate_from_tcl
Jingyang, Teh
