14 years agoGetting the System Time in VHDL
Hello, Attached below is my VHDL code for a digital clock. Right now the code sets the default time as 12:00:00 AM, as seen from lines 35-38. I was wondering if there was some sort of command i...
14 years agoThere isn't anything like that.
The default time will be hardcoded into the design during compilation. At best, you could have a way to automatically set the time of the compilation as the default time for your clock. There isn't any VHDL command for this, AFAIK, but you can use a generic and TCL script to set the generic's value. But short of you adding a network interface, with a UDP/IP stack and a NTP client implementation or something of the sort, there's no way for your design to automatically retrieve the computer's time.
