12 years agoGetting Started - Simple Socket Server, Board Test System, Cyclone III
I am trying to run the Simple Socket Server using the Board Test System for a Cyclone III Dev Board. In the Terminal Emulator everything seems to be working. It prints this information:
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Please start Command Prompt Start->Run->cmd or type cmd in "Search programs and files" field in Wndows 7 then type "telnet 10.32.201.4 30" to connect Window 7 users may need to activate telnet first. Control Panel->Programs->Turn Windows features on or off-> enable telnet !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! I have activated telnet but my computer cannot connect. I'm trying to determine if this issue is being caused by my FPGA board, my computer, my network, or my software. I am using a Linksys Ethernet switch to link my Cyclone III, Computer, and Internet. I've been told that the problem might be due to an extra VLAN tag that is automatically inserted into the work TCP/IP (apparently there is a way to turn this off but the protocol is hardwired into some machines and can't always be disabled). If this is the case then I'm not sure I have many options. I'm pretty new to this stuff and I'm not sure what the socket server is actually doing. Should I be able to run the server without internet access? I tried connecting the FPGA to the computer, while disconnecting the internet cable, and it doesn't work at all (it doesn't get to the point where it tells me to use command prompt). Additionally, it's already communicating with the computer at some basic level because it's able to create the simple socket server and tells me which port it's listening on. If the tag is in the Ethernet protocol, would it still be able to get that far? It seems like it is communicating and functioning to some degree, but I can't figure out why it doesn't work. Here's the full print out. Any help is much appreciated: =============== Software License Reminder ================ This software project uses an unlicensed version of the NicheStack TCP/IP Network Stack - Nios II Edition. If you want to ship resulting object code in your product, you must purchase a license for this software from Altera. For information go to: "http://www.altera.com/nichestack" ===================================================== InterNiche Portable TCP/IP, v3.1 Copyright 1996-2008 by InterNiche Technologies. All rights reserved. prep_tse_mac 0 Your Ethernet MAC address is 00:07:ed:11:41:a6 prepped 1 interface, initializing... [tse_mac_init] INFO : TSE MAC 0 found at address 0x20003000 INFO : PHY Marvell 88E1111 found at PHY address 0x12 of MAC Group[0] INFO : PHY[0.0] - Automatically mapped to tse_mac_device[0] INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED MARVELL : Mode changed to RGMII/Modified MII to Copper mode MARVELL : Enable RGMII Timing Control MARVELL : PHY reset INFO : PHY[0.0] - Checking link... INFO : PHY[0.0] - Link not yet established, restart auto-negotiation... INFO : PHY[0.0] - Restart Auto-Negotiation, checking PHY link... INFO : PHY[0.0] - Auto-Negotiation PASSED INFO : PHY[0.0] - Link established INFO : PHY[0.0] - Speed = 100, Duplex = Full OK, x=0, CMD_CONFIG=0x00000000 MAC post-initialization: CMD_CONFIG=0x04000203 [tse_sgdma_read_init] RX descriptor chain desc (1 depth) created mctest init called IP address of et1 : 192.168.1.234 Created "Inet main" task (Prio: 2) Created "clock tick" task (Prio: 3) Acquired IP address via DHCP client for interface: et1 IP address : 10.32.201.4 Subnet Mask: 255.255.255.0 Gateway : 10.32.201.1 Simple Socket Server starting up [sss_task] Simple Socket Server listening on port 30 Created "simple socket server" task (Prio: 4) !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Please start Command Prompt Start->Run->cmd or type cmd in "Search programs and files" field in Wndows 7 then type "telnet 10.32.201.4 30" to connect Window 7 users may need to activate telnet first. Control Panel->Programs->Turn Windows features on or off-> enable telnet !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! UPDATE: This issue has been resolved. Turns out the FPGA Ethernet MAC address needed to be added to the network before it was allowed to communicate. NO VLAN TAG!No RepliesBe the first to reply
