9 years agoget the fitter to stop after placement (i.e. not do routing)
Hi, does anybody know how to get the fitter to place a design but not route it? I'd like to sweep across a bunch of fitter seeds and dump out the placement (using backannotation to produce set_...
9 years ago --- Quote Start --- All you need to do is create an account on myAltera https://www.altera.com/mal-all/mal-signin.html?resource=%2Fcontent%2Faltera-www%2Fglobal%2Fen_us%2Findex%2Fmyaltera%2Fmal-home.html&$$login$$=%24%24login%24%24&j_reason=unknown&j_reason_code=unknown Then you can raise a ticket in the "mysupport" section --- Quote End --- Thanks Tricky, I will give it a try.
