13 years ago
get_service_paths master returns null when system-console invoked remotely over ssh
I have a Qsys system with a JTAG master in a Linux machine. I download the synthesized bitstream over USB JTAG cable into an Altera DE4 board (Stratix IV FPGA) attached to this machine.
Now, I remotely login to this machine using ssh (ssh -XY machinename). I open system console
In system-console when the following command is sourced from the tcl script
set jtag_master [lindex [get_service_paths master] 0];
jtag_master does not getting any value
and fails in successive steps (ie. opening the service etc..)
Strangely this happens only when system-console is remotely invoked (eg. from ssh). If I try running system-console locally and jtag_master gets a valid value. I am using Quartus 12.0.
I can confirm that my JTAG connection works without any issue as jtagconfig returns correctly.
I did try the same command with different numbers as suggested in some of the previous posts ie.
set jtag_master [lindex [get_service_paths master] 1];
set jtag_master [lindex [get_service_paths master] 2]; etc.. with no luck.
Appreciate your inputs,
Deepak
    [solved]
    Turns out that the problem is related to installation of Linux JTAG usb blaster driver. I have 2 Quartus versions - 12.0 and 12.1 in my drive. I installed usb blaster driver from 12.1 according to the procedure described here - eecg.toronto.edu/~laforest/USB-Blaster-Debian.html. Later, I decided to switch my Quartus version to 12.0. But the driver file (<Quartus install path>/linux/quartus/linux/pgm_parts.txt) was sourced from 12.1. To fix the issue, I switched the driver file to match my Quartus version (12.0).
    As a sanity check for correct driver installation, execute
    >jtagconfig
    and it should return
    1) USB-Blaster [5-2]
    024090DD EP4SGX230(.|ES)
    for SIV device
    The driver installation procedure for Ubuntu/Linux can be found here - eecg.toronto.edu/~laforest/USB-Blaster-Debian.html
    I hope this post helps many others!
    Deepak
    Hi wombat,
    I still face the issue. I will paste the output of get_service_paths below. Can you please take a look ?
    Here is the procedure I followed:
    1. download bitstream (i use a time limted ethernet core)
    >download_sof ./DE4_Ethernet_time_limited.sof
    File ./DE4_Ethernet_time_limited.sof contains one or more time-limited megafunctions that support the OpenCore Plus feature that will not work after the hardware evaluation time expires. Refer to the Messages window for evaluation time details.
    Info (210040): SRAM Object File ./DE4_Ethernet_time_limited.sof contains time-limited megafunction that supports OpenCore Plus feature -- Vendor: 0x6AF7, Product: 0x00BD
    Info: *******************************************************************
    Info: Running Quartus II 32-bit Programmer
    Info: Version 12.1 Build 177 11/07/2012 SJ Full Version
    Info: Copyright (C) 1991-2012 Altera Corporation. All rights reserved.
    Info: Your use of Altera Corporation's design tools, logic functions
    Info: and other software and tools, and its AMPP partner logic
    Info: functions, and any output files from any of the foregoing
    Info: (including device programming or simulation files), and any
    Info: associated documentation or information are expressly subject
    Info: to the terms and conditions of the Altera Program License
    Info: Subscription Agreement, Altera MegaCore Function License
    Info: Agreement, or other applicable license agreement, including,
    Info: without limitation, that your use is for the sole purpose of
    Info: programming logic devices manufactured by Altera and sold by
    Info: Altera or its authorized distributors. Please refer to the
    Info: applicable agreement for further details.
    Info: Processing started: Sat Apr 13 05:33:46 2013
    Info: Command: quartus_pgm --quiet -z -m JTAG -o p;./DE4_Ethernet_time_limited.sof
    Info (213045): Using programming cable "USB-Blaster [8-2]"
    Info (213011): Using programming file ./DE4_Ethernet_time_limited.sof with checksum 0x09B20EC8 for device EP4SGX230KF40 at 1
    Info (209060): Started Programmer operation at Sat Apr 13 05:33:54 2013
    Info (209016): Configuring device index 1
    Info (209017): Device 1 contains JTAG ID code 0x024090DD
    Info (209007): Configuration succeeded -- 1 device(s) configured
    Info (209011): Successfully performed operation(s)
    Info (209061): Ended Programmer operation at Sat Apr 13 05:34:12 2013
    Please enter i for info and q to quit:
    [I don't close this message]
    In a new tab,
    2. open system console in command line mode
    > system-console -cli
    Apr 13, 2013 5:38:42 AM com.altera.systemconsole.internal.core.SystemConsole$PluginDiscovery run
    INFO: Finished initialization
    Apr 13, 2013 5:38:42 AM com.altera.systemconsole.internal.core.SystemConsole logInfo
    INFO: Finished discovering JTAG connections
    Apr 13, 2013 5:38:48 AM com.altera.systemconsole.internal.core.SystemConsole logInfo
    INFO: Finished discovering USB connections
    Version 12.0 178
    associated documentation or information is expressly subject
    Agreement, or other applicable license agreements, including,
    Welcome to Altera's System Console
    This Tcl console provides access to the hardware modules instantiated in your
    FPGA. You can use System Console for all of the following purposes:
    * To start, stop, or step a Nios II processor
    * To read or write Avalon Memory-Mapped (Avalon-MM) slaves using special
    masters
    * To sample the SOPC system clock as well as system reset signal
    * To run JTAG loopback tests to analyze board noise problems
    * To shift arbitrary instruction register and data register values to
    instantiated system level debug (SLD) nodes
    In addition, the directory <QuartusII Dir>/sopc_builder/system_console_macros
    contains Tcl files that provide miscellaneous utilities and examples of how to
    access the functionality provided. You can include those macros in your
    scripts by issuing Tcl source commands.
    INFO: Executing startup script /home/deepak/altera/12.0/quartus/sopc_builder/system_console_macros/system_console_rc.tcl
    % set mypath [ lindex [ get_service_paths master ] 0 ]
    % open_service master $mypath
    path cannot be found
    while executing
    "open_service {master} {}"
    while executing
    "open_service master $mypath"
    now, i observe a very strange behavior summarized below:
    - My script to write into JTAG master is as follows:
    open_service master $jtag_master;
    master_write_32 $jtag_master $reg_400 0x00000000;
    close_service master $jtag_master;
    I download the bitstream and run the above script, it runs perfectly fine. Then I wait 10 minutes and run the same script again. This time, open_service master fails giving the folloiwing error:
    Path cannot be found
    while executing
    while executing
    "open_service master $jtag_master"
    To run the script again, I need to reboot the PC.
    Looks like the JTAG master times out after some time. Has this behavior been observed before ? Appreciate your thoughts.
    Update: I dont see any obvious STA timing errors in the design (from report). Also, I tried changint the DE4 boards to make sure that its not a hardware issue. I can confirm that I see this issue even if I change the board. Looks something is wrong in software settings. Any pointers ?
    Deepak
    Thanks. Your are right. After some trials, I determined that its not an issue with System console. I have narrowed the issue down to a problem with the bitstream. Thanks!
    SystemConsole can't tell whether it has been invoked locally or remotely so that behaviour is very strange. Something else must be different. Are you using the same command line arguments both times?
    If you have more than one master available then get_service_paths will return a list of masters, whether you use 0 1 2 etc depends on where your desired master is in the list. Can you show us the complete output from get_service_paths master?
