13 years agoget_service_paths master returns null when system-console invoked remotely over ssh
Hi, I have a Qsys system with a JTAG master in a Linux machine. I download the synthesized bitstream over USB JTAG cable into an Altera DE4 board (Stratix IV FPGA) attached to this machine. ...
13 years ago[solved]
Turns out that the problem is related to installation of Linux JTAG usb blaster driver. I have 2 Quartus versions - 12.0 and 12.1 in my drive. I installed usb blaster driver from 12.1 according to the procedure described here - eecg.toronto.edu/~laforest/USB-Blaster-Debian.html. Later, I decided to switch my Quartus version to 12.0. But the driver file (<Quartus install path>/linux/quartus/linux/pgm_parts.txt) was sourced from 12.1. To fix the issue, I switched the driver file to match my Quartus version (12.0). As a sanity check for correct driver installation, execute >jtagconfig and it should return 1) USB-Blaster [5-2] 024090DD EP4SGX230(.|ES) for SIV device The driver installation procedure for Ubuntu/Linux can be found here - eecg.toronto.edu/~laforest/USB-Blaster-Debian.html I hope this post helps many others! Thanks Deepak
