In my Design I use the Cyclone 10GX 10CX105YF780E5G FPGA together with the Micron MT25QU512ABB1EW9 Flash chip.
I want to use the Intel Generic Serial Flash Interface in my design to be able to access the flash from within the NIOS II C Code.
I Downloaded the Design example (Generic Serial Flash Interface and Nios II booting ), changed the FPGA from Cyclone5 to 10GX 10CX105YF780E5G and upgraded all the platform designer components to the Quartus Prime Pro Edition 19.1(The version I am Currently using). I also imported the design examples Nios Project and bsp project. But I did not change any further settings. The NIOS II Processor Reset Vector is still located under the intel_generic_serial_flash_interface_top_0.avl_mem with a offset of 0x00f00000 (Reset Vector Absolute adress = 0x2f00000). The Generic Serial Flash Interface IP's Control Register:(under hidden parameters) is still 0x00000101.
Before generating hdl in the platform designer, I opened the bsp editor (witch opened the generic_flash_access.sopcinfo file that came with the design example). Under the "linker script" tab there are the following Linker Memory Regions:
| onchip_memory2_0 | 0x04040020 - 0x0407FFFF | onchip_memory2_0 | 262112 | 32 |
| onchip_memory2_0_BEFORE_EXCEPTION | 0x04040000 - 0x0404001F | onchip_memory2_0 | 32 | 0 |
| intel_generic_serial_flash_interface_top_0_avl_mem | 0x02F00020 - 0x03FFFFFF | intel_generic_serial_flash_interface_top_0_avl_mem | 17825760 | 15728672 |
| reset | 0x02F00000 - 0x02F0001F | intel_generic_serial_flash_interface_top_0_avl_mem | 32 | 15728640 |
| intel_generic_serial_flash_interface_top_0_avl_mem_BEFORE_RESET | 0x02000000 - 0x02EFFFFF | intel_generic_serial_flash_interface_top_0_avl_mem | 15728640 | 0 |
But after I Generate HDL... and open the bsp editor again the following errors appear:
- SEVERE: .entry section mapping not created because reset memory region not located at base address: 0x2f00000
- SEVERE: [Error] altera_hal_linkerx_generator: The section mapping ".entry" is missing.
- SEVERE: [Error] altera_hal_linkerx_generator: Required linker section mappings do not exist: "[.entry]"
Also the following Linker Memory Regions disappeared: intel_generic_serial_flash_interface_top_0_avl_mem, intel_generic_serial_flash_interface_top_0_avl_mem_BEFORE_RESET and reset.
Pressing Restore Defaults... did not help.
Changing the Generic Serial Flash Interface IP "Device Density" to 512, for the MT25QU512ABB1EW9 flash and regenerating hdl obviously did not fix the errors either.
I think for some reason the new generated "generic_flash_access.sopcinfo" file does not have the Memory Device "Iitel_generic_serial_flash_interface_top_0_avl_mem" and then those Linker Memory Regions cannot be created.
How can I fix this?
When setting the NIOS II Processor Reset Vector to onchip_memory2_0 with a offset of 0x00000000 everything works and I can program the VHDL and c code with the jtag. I can read and write to the flash, everything works. But then off Corse I cannot boot from flash(Because of Reset Vector...), witch is pointless.
Is Quartus Prime Pro Edition 19.1 / Cyclone10 not compatible with Generic Serial Flash Interface IP?
Please help!
